J a m e s
Fitting a boost gauge.
You can tee it off the vacuum hose to the clocks inside the car. That's probably the easiest place.
Gavin
yeah i agree...i use the mfa pipe under the dash...any vac pipe should do apart from the ecu one...so you can t piece at the rear of the inlet if you'd prefer
