vwdeviant
Retro-fitiing ABS systems
Ok strange question but how much work is involved in retro-fitting ABS into a non-ABS car?
Pump (obviously) Sensors and Triggers Wiring loom... anything else?
Master Cyl, resevoir, Servo, BPPS, the 4 wheel sensors, pump unit, ECU, wiring loom(s), relays, Dash Light, front Hubs, rear ABS cages, pump feed pipes, brake pipes and so on... you can see why it was a £1600 option!
Ouch! Any-one done it?
I'm thinking A big engine and Brembos without ABS could be asking for Hedge/tree/ditch interface....(Not me BTW..;) )
