was8v 0 Posted September 28, 2007 VAG-COM says my left rear ABS sensor is duff. I haven't had a look yet but if I need a new sensor I notice rear sensors are £30 more than fronts. Does anyone know the difference between front and rear sensors? Is the only difference the length of the wire? In which case I could just buy a front sensor and extend the loom? Has anyone actually seen both togther that can give an answer? Cheers. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 28, 2007 Rear sensors come with loom attached, if you look at the price of the looms for the fronts you'll see they are more expensive... Quote Share this post Link to post Share on other sites
was8v 0 Posted September 29, 2007 Is that the only difference though? The loom can easily be extended using the old loom some heatshrink and solder. Quote Share this post Link to post Share on other sites
was8v 0 Posted October 3, 2007 bump. any difference except the length of wire and price? Quote Share this post Link to post Share on other sites
