Martyn_McG
oil leak
is it common for vr's to leak from where the filter housing meets the engine?
my rado keeps leaving its mark everywhere and as far as i can tell its that gasket . .
I believe mine is doing the same thing actually fella.
My local mechanic said that the this is a common problem with VRs, the forum might be able to offer some insight into this aswell!
When's she due for her next oil change?
*i'm trying to get the diagram off vagcat to check out the arrangement of parts, but it doesn't seem to be working*
its ok i had already ordered the gasket and 2 bolts needed to do it just to be on the safe side!!
the gasket is about £6 and £2 each for new bolts from a vw dealership ( i dont like re using the old bolts!!)
i had just recently changed the oil so im gonna try and save as much of it as i can when doing the repair!!
v021 115 446 a - for the gasket, i payed £6.53
vN 100 362 03 - for the bolts, dont really need replacing though
as i went to fit them i realsied it was actually one of my pressure switches jsut above that was leaking, im sure the bloke on parts at my local stealers thinks im stalking him i go down there twice a week!
