cheesey 0 Posted May 3, 2008 putting the door panel back on the corrado giving you greif :bad-words: that bastid door pin keep flopping about :help: not going where its supposed to arggh you sh%^&&nt :censored: i sussed it out today just get the biro thats sitting leeking in your door pocket and take the insert out and put the outter casing through the hole in the panel and over the pin it go's through the hole every time :clap: :clap: :clap: :clap: :clap: good eh im not even gonna charge you for this info :notworthy: but you can make a donation to this web site if you want to Quote Share this post Link to post Share on other sites
JMC 0 Posted May 3, 2008 I tie on a piece of cotton thread and put that through the hole - always works a charm. Drove me mad the first time though - spent ages trying to figure it out. Good to see I'm not the only one :lol: :lol: Quote Share this post Link to post Share on other sites
til2143 0 Posted May 3, 2008 putting the door panel back on the corrado giving you greif :bad-words: that bastid door pin keep flopping about :help: not going where its supposed to arggh you sh%^&&nt :censored: i sussed it out today just get the biro thats sitting leeking in your door pocket and take the insert out and put the outter casing through the hole in the panel and over the pin it go's through the hole every time :clap: :clap: :clap: :clap: :clap: good eh im not even gonna charge you for this info :notworthy: but you can make a donation to this web site if you want to Good plan, you should patient that :D Quote Share this post Link to post Share on other sites
boost monkey 0 Posted May 3, 2008 I just put it back on not like a retard :roll: Really isn't that hard fellas, unless your doorpins are bent :eek: :lol: Quote Share this post Link to post Share on other sites
paul20v 0 Posted May 5, 2008 putting the door panel back on the corrado giving you greif :bad-words: that bastid door pin keep flopping about :help: not going where its supposed to arggh you sh%^&&nt :censored: i sussed it out today just get the biro thats sitting leeking in your door pocket and take the insert out and put the outter casing through the hole in the panel and over the pin it go's through the hole every time :clap: :clap: :clap: :clap: :clap: good eh im not even gonna charge you for this info :notworthy: but you can make a donation to this web site if you want to Good plan, you should patient that :D sorry i had too, PATENT that :salute: Quote Share this post Link to post Share on other sites
VWRETROMAN 0 Posted June 3, 2008 I just screwed the door pins back on first then took the cover that goes round it off the door card and it fits through the hole np. Quote Share this post Link to post Share on other sites
raddovr6 0 Posted June 3, 2008 Neat trick, Well done! I always used to fiddle around with the card loose trying to screw the pin back on, if you don't screw the pin all the way down you have enough play to re-align the card back into place. Still a pain though, used to drive me nuts. I will keep this in mind :) Quote Share this post Link to post Share on other sites
KADVR6 0 Posted June 3, 2008 i just snipped the wire off completly, and put a rubber bung in the hole. looks much cleaner. karl Quote Share this post Link to post Share on other sites
