tribetype40
FAN TEMP
Just a quicky , hopefully,....!
does anyone know the temp the fans are supposed to come on at?
I have a '95 Corrado VR6
Doug
Hmmm thought so. Looks like there a little problem with mine (re wired the engine bay after a wire melt down courtesy of the lighting loom!) mine got up to just under 110 and no fan...? any ideas/ways to check the temp switch etc??
Doug
It should not get to 110 deg without fan...
My fans currently do not work (getting them sorted tomorrow), and it gets to 110 when the warning light comes on- driving it normally however (even without fans) water temp stays around the 80-90 mark (even without fans)- just be prepared to switch off and let it cool down if the water temp gets too high..
If I recall the fans should be on by the 100 deg mark..
if it gets a bit high any time and you are worried turn the heater on in the car flat out at full tempurature this will help cool the car down ,
but you will roast , upside is you can shower the car is a lot harder to fix if you boil it to much. :)
