cvw74 0 Posted November 26, 2008 I have just had componenets and door pod build/install put in the car, driving off, undo window, only my side works??? The lads checked all electrics and assured me that the loom had not been damaged. I'm no good with electrics, you could here the relays working when switch pressed and he assures there's power going to motor, the windows were perfectly happy before so I can't see it being the motor...the lights on the switches are working, i'm guessing if fused neither windows would be working. any help would be much appreciated, thanks Share this post Link to post Share on other sites
VR6 0 Posted November 26, 2008 Can you have a look through the search... search.php?keywords=%2Bwindows+%2Bstopped&terms=all&author=&fid[]=19&sc=1&sf=all&sr=topics&sk=t&sd=d&st=0&ch=300&t=0&submit=Search I'm sure the answer will be in there. Share this post Link to post Share on other sites
