corradog60stage4
Fuel gauge sender woes.
If your fuel gauge acts funny or is completely empty at time and sometime full.
This is maybe the cause of your problem like I had to diagnose on my sister's jetta.
With the tank full it would sometime read full and parked on the driveway at a angle would read empty.
I took out the pump like 3 times to ensure the float was not binding and everything. Outside of the tank the lever would work find when I moved it up and down but not once it was inside the tank.
It was a cracked in tank sender.
232323232%7Ffp389%3Enu%3D3242%3E743%3E362%3EWSNRCG%3D3235827867%3C2%3Bnu0mrj
replaced a new one and works great now.
