jimmyvwjunkie
HELP!!!!!!!! NO HEATING OR BLOWER
hey guys got a problems when i put the car heating on only cool air comes out. even when the heater setting are at max heat. anyone know why???
also there seems to be no air coming out the top vents that hit the window to stop it steaming up. i can hear the air trying to reach there but sounds as though theres a blockage or vents closed, anyone know faults with the early heater system of a 1991 corrado 16v. my heed is sare with the problemo. :mad2:
Pull off the dial facia panel and you will find 4 screws holding the dial mechanism in, undo those four screws and pull it out so you can see behind it, then turn the dial and see if it is push/pulling the cable, if it isn't you know it's the dial mechanism broken, if it is then I'm afraid you'll have to investigate further down the line. Have you just bought the car? If so check that the heater matrix hasn't been disconnected as they are prone to breaking....
Kip it's a 91 16v so old style sliders... Easy way to check is to pop the stereo out and look down! :norty:
Possibly the cables need sorting out? do you feel any resistance when sliding them?
Do you get any heat from anywhere?
hey thanks mate, well i sometimes get heat for like 5 mins then goes cold (strange). but other than that nothing.
Doh!!! I'll get my coat :D :D
God I can't even do a quote without messing it up today, I hope the rest of the year goes better...............
Hmm sounds like it could be an air-lock in the matrix... how's the engine temps?
eh engine temps normally sitting at 100-103
