myles
please identify gearbox
lads can anyone help me indetify a vw gearbox please.
3 numbers.
stamped on top plate. fvs 19101 371020
inside bellhousing. ww07 02j301107c
beside drive flange. 02j 301103fp5 r1
02a is on the rubber plug on top and also stamped on the bearing behind the clutch arm.
thanks lads
well it's an 02J, as they are later items than the 02A although share 02A parts, hence the numbers with 02A on.
What size are the drive flanges? - probably mk4 bigger 110mm ones (100mm on Corrado/mk3)
mm, FVS is the box code and the number indicates a 2001 box, it's not a golf mk4 one though.
mk4's have an FBS, FBX, FBK, FBV
6 speed is DRW ERR EFF
ah, a 2WD TT 5sp box is EVS, could it be that?
david, it could be. the engine in the car is an aum which he said came out of a low mileage tt180. so its only a five speed , mystery solved i'd say !!
