akacheesy 0 Posted January 1, 2004 Any tips dudes? Quote Share this post Link to post Share on other sites
crazymarcel 0 Posted January 1, 2004 Make sure the wheels are straight, socket and pull Quote Share this post Link to post Share on other sites
akacheesy 0 Posted January 1, 2004 24mm long reach or just a normal one? I guess you have to remove the centre bit too? Haven't tried it yet but I suppose it just pulls off? Quote Share this post Link to post Share on other sites
Pete 0 Posted January 1, 2004 Mine is not on quite straight, is it easy to adjust myself??? Quote Share this post Link to post Share on other sites
Henny 0 Posted January 1, 2004 If you've got a standard wheel on, the horn push just pulls straight off... Be careful though, 'cos there's a wire attached to it and you don't want to break it! Then there's a 24mm nut which you can get off with a normal socket with a smallish extension bar on a reasonable sized ratchet. Make sure that your road wheels are dead straight before you take the wheel off! The splines on the shaft are quite fine, so it's pretty easy to adjust it if it's a little bit off center by removing it and turning it slightly.... 8) Whatever you do, don't be tempted to use the steering lock to push against while undoing or tightening the nut as you will damage it... Quote Share this post Link to post Share on other sites
