Stryker
MOT Question
Hey guys, quick question, if one of your full beams is not working does it cause a MOT Failure?
cheers
eh, sure i've just responded to this...
Its definately a MOT failure. Mine failed for this last month turned out to be the relays on my wiring loom. Do you have an uprated headlight wiring loom?
Daft question - have you checke the bulb?
sounds like wiring.
get some pics up of the back of your headlights. we should be able to tell whether it's got an uprated loom or not.
ok just had a play around and switched the headlights around to see if the passenger side one would work plugged into the drivers side socket and it worked fine so there must be something wrong with the headlight itself
