8vMatt
Will Audi 288mm brakes fit?
I've seen a complete disc, caliper and carrier set up going for a good price and was wondering if there was anything that would stop this lot fitting my 94 VR6?
from what sort of Audi tho
they use the same pcd on certain models only
early A3, and TT mk1 have 5x100
later stuff as well as early 90's stuff use 5x112 ie TT mk2 and S2 Coupe
After attempting to fit my old A3 Turbo 288mm Black Diamond front discs this afternoon and finding out that they foul the caliper hangers the answer is no. The calipers fit though and I suspect after comparing part numbers the Golf Mk3 288mm discs would be needed instead.
Grateful if some one can confirm that though.
