eddy.h 0 Posted March 16, 2010 nice job on the switches, was it difficult to do? Any advice would be appreciated as I plan on doing this. Where did you get your LED's etc Cheers Anthony got the led form maplin Quote Share this post Link to post Share on other sites
eddy.h 0 Posted June 5, 2010 a cupall of jubs i been mening to post fitted a k&n cone filter & a alloy lower strut brace not a bolt on itam had to make it fit2.8l 24v Climatronic system.pdfPhoto0060.jpg[/attachment:9k7d7on6]Photo0061.jpg[/attachment:9k7d7on6] Quote Share this post Link to post Share on other sites
eddy.h 0 Posted September 5, 2010 fitted bbm fuel rail but had to remove the boost return pip to get the fuel hose to fit so i think i will be going mk3/4 golf style fpr adaptor & fpr to get the boost return pip back on newman cam 264 & adustadle sprocket fitted to dos not fell ne faster i have a sns s4 chip will be geting a new chip but need to get the 315cc (red) fuel injectors fist allso going chargecooler gathering the parts :grin:climatronic wiring-Golf from May 01.pdfPhoto0088.jpg[/attachment:16tmhaqt]Photo0090.jpg[/attachment:16tmhaqt] Quote Share this post Link to post Share on other sites
eddy.h 0 Posted September 5, 2010 some of the parts for the chargecooler ordering the radiator next Friday going to yous the bailey focus rs chargecooler reservoir need to find the time to fit the battery in the boot cable is in all parts will be power coated blackPICT0001 (2).JPG[/attachment:6d9vwk9q] :grin: Quote Share this post Link to post Share on other sites
eddy.h 0 Posted October 2, 2010 got the battery (new) in boot & powering the car need to finish the box now i can get on to the water to air intercoolpassat climatronic wiring diags.pdfPICT0008.JPG[/attachment:kwibjs3k]climatronic wiring-Golf from May 01.pdfPICT0004 (2).JPG[/attachment:kwibjs3k]2.8l 24v Climatronic system.pdfPICT0006 (2).JPG[/attachment:kwibjs3k]PICT0007.JPG[/attachment:kwibjs3k] & fitted a bosch lambda sensor idles ok now Quote Share this post Link to post Share on other sites
eddy.h 0 Posted December 4, 2010 air to water intercooler fitted small water Lek :mad2: have a hose on order for that seems to be better than the fmic i had on they before :grin: also fitted a bar-tek RS G60 bypass vale kit will be selling the isv reroute kit( home made) the fmic is going on my m8 G60 also had the cylinder head of duo to snapping a exhaust manifold to head bot & made a new injector wing lume runs a hole lot betterclimatronic wiring-Golf from May 01.pdfPICT0001.JPG[/attachment:1ondhc6v]2.8l 24v Climatronic system.pdfPICT0032.JPG[/attachment:1ondhc6v] Quote Share this post Link to post Share on other sites
eddy.h 0 Posted December 10, 2010 order myself some pulleys http://www.bar-tek-tuning.com/lshop,sho ... 7,31,,.htm should be saving for bodywork thou :scratch: Quote Share this post Link to post Share on other sites
VR6Joni 0 Posted December 11, 2010 Chargecooler rad looks a good size! Where did you get it from? Quote Share this post Link to post Share on other sites
eddy.h 0 Posted December 11, 2010 Chargecooler rad looks a good size! Where did you get it from? got it form http://www.chargecooler.co.uk m8y & the pump Quote Share this post Link to post Share on other sites
eddy.h 0 Posted December 18, 2010 got the pulleys today look rear-lee good :grin: but to-much snow :brickwall: to be fitting them2.8l 24v Climatronic system.pdfPICT0003.JPG[/attachment:2imfr3ip]PICT0002.JPG[/attachment:2imfr3ip] Quote Share this post Link to post Share on other sites
drewiee99 0 Posted December 20, 2010 nice pulleys did you get these made as a one off? Quote Share this post Link to post Share on other sites
eddy.h 0 Posted December 20, 2010 nice pulleys did you get these made as a one off? no m8y got them form bar-tek including post £188. these a link a couple of post up :grin: Quote Share this post Link to post Share on other sites
eddy.h 0 Posted January 2, 2011 got the pulleys fitted wade the old pulleys2.8l 24v Climatronic system.pdfPICT0001 (2).JPG[/attachment:nfebxruj]PICT0002 (3).JPG[/attachment:nfebxruj] have also order a vdo volt meter cupall of weeks ago the wire for the battery lamp at the alternator end snap & cost me a days work the own-ell time in 3 years its lite me down so not bad for a G60 :grin: Quote Share this post Link to post Share on other sites
JMC 0 Posted January 2, 2011 got the pulleys fitted wade the old pulleys2.8l 24v Climatronic system.pdfPICT0001 (2).JPG[/attachment:qk4cdt6b]PICT0002 (3).JPG[/attachment:qk4cdt6b] have also order a vdo volt meter cupall of weeks ago the wire for the battery lamp at the alternator end snap & cost me a days work the own-ell time in 3 years its lite me down so not bad for a G60 :grin: Those new pulleys look good mate - I'd be interested to know how you get on with them once you've fitted and driven with them for a while. Quote Share this post Link to post Share on other sites
eddy.h 0 Posted January 2, 2011 got the pulleys fitted wade the old pulleys2.8l 24v Climatronic system.pdfPICT0001 (2).JPG[/attachment:1g4ga2om]PICT0002 (3).JPG[/attachment:1g4ga2om] have also order a vdo volt meter cupall of weeks ago the wire for the battery lamp at the alternator end snap & cost me a days work the own-ell time in 3 years its lite me down so not bad for a G60 :grin: Those new pulleys look good mate - I'd be interested to know how you get on with them once you've fitted and driven with them for a while. so far so good my be better with a lighter flywheel ( on my list :grin: ) could do with a new clutch Quote Share this post Link to post Share on other sites
JMC 0 Posted January 2, 2011 Hmm, I've got a lightened flywheel, and have always wondered about lightening the pulleys, but have heard the harmonic balancer shouldn't be lightened otherwise the engine can shake. With a full weight flywheel though, presumably that isn't as much of an issue so you should be ok. With everything lightened you'd need to make sure the balance for it all was spot on. Keep up the reports :) Quote Share this post Link to post Share on other sites
drewiee99 0 Posted February 2, 2011 ok little confused with these light weight crank pulleys, those bartek ones are all one piece the origianl ones that come off there is a big round heavy weight that sits inside the crank pulley, can you tell me what its purpose of it is, and what gains will be had by light weight ones. found a pic of a VW motorsport set up off a rallye it used a toothed belt but still uses the heavy weight? Quote Share this post Link to post Share on other sites
eddy.h 0 Posted February 2, 2011 its sir-post to lite the engine spin up faster whan accelerating the heary weight that sits inside the crank pulley is a harmonic balancer the pic you posted the green part looks abit defrut not suer if that is a harmonic balancer & the power steering pulley looks small i am happy with the pulley Quote Share this post Link to post Share on other sites
eddy.h 0 Posted February 5, 2011 have fitted a g-werks G60 soild belt tensioner it has gave me about 2/3psi moor the old tensioner did need replacing the bilt is new don about 1000 mils Quote Share this post Link to post Share on other sites
eddy.h 0 Posted September 29, 2013 wow haven't posted her in a wiall I don a lot to it mk4 Golf raer calpiers Porsche 996 fornt calipers 305/28mm disc fitted my concept P wheels 8-16" with Pirelli pzero tyres new superchager form BBM with gt70 intake porting rsr outlet porting & superwide tooth belt now with 65mm pulley BBM stage 5 250 chip 250 kpa map sensor tt 268/260 cam form BBM will post sum pic Quote Share this post Link to post Share on other sites
eddy.h 0 Posted September 29, 2013 [ATTACH=CONFIG]75836[/ATTACH][ATTACH=CONFIG]75837[/ATTACH][ATTACH=CONFIG]75838[/ATTACH][ATTACH=CONFIG]75839[/ATTACH] Quote Share this post Link to post Share on other sites
