lockdown 0 Posted October 20, 2009 Hello everyone. Quick question. I think they are called cam followers. I've had them out of the head for a while and all the oil has drained out of them. Can they be put back in like normal and they will work fine or if there a way of refilling them before I put them back in? Or is it just a case if having to buy a new set? Thanks guys Quote Share this post Link to post Share on other sites
lockdown 0 Posted October 20, 2009 Any ideas? Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted October 20, 2009 Any ideas? the bentley bible lists the following for the engine code PG cam follower lubricate contact surface do not interchange check camshaft axial play before installing install with contact surface down hope that helps :) Quote Share this post Link to post Share on other sites
lockdown 0 Posted October 20, 2009 Laarvly thanks dude Quote Share this post Link to post Share on other sites
VR6Joni 0 Posted October 20, 2009 Immerse them overnight in fresh oil, the same way they sit in the engine as this allows them to draw oil in. I actually left my new ones for a few days and I got next to no tapping when it was fired up. Quote Share this post Link to post Share on other sites
lockdown 0 Posted October 21, 2009 Ah nice one mate. Just the sort of info I was after. Thanks lads Quote Share this post Link to post Share on other sites
