StueyB
Flat rear bench into a late humped car?
In the process of replacing an extremely miss matched interior and looking for an answer to a question.
Have used the search but i don't think this has been covered.
Looking to fit a flat rear bench into a car which has the mounting points for a hump'd one to make up a full matching interior.
However I'm wondering whether the flat bench will fit with the later style hump fixings in place?
I guess you could hack these out but i'd like to avoid this if possible.
Does anyone bar smarties have the answer?
yes it will. you just need to remove the bracket for the center rest.
yes, removing the bracket is the way, that's what I did in mine :D
btw, if you remove the bracket in the spartan way (like me), it will become useless :lol:
When you say bracket do you mean the one which the four screws go into or the on centre rest clips into?
And if you remove that bracket and don't want it, you can sell it to me :D
Will happily do this is i decided to remove it.
Spartan way... :lol:
I spartan'd a parcel shelf once... :lol:
Thanks for the help guys.
To do it right you will also need the plastic trim from the rear of the handbrake back to the seat
yes, and that took me 2 years of search :nuts:
good luck anyway!!
good luck anyway!!
I have that trim if you need it
