skinnyman9000
Misfire/erratic idle
Recently the C has developed a slight misfire, sounds like its on race cams, but its not.
I had a gander around the engine bay and noticed that the ends of one of the HT leads (where it attaches to the spark plug) had some white powder around it. Is it likely that the spark plug is knackered, and that this is causing the misfire? And that a simple spark plug replacement (on all 4 obvs) would solve the issue?
Could just be a bit of corrosion. Try giving the lead ends and plug tops a good clean up ans see what occurs.
