waynos 0 Posted May 26, 2010 hi guys can anyone help? i just need to find out what wire does what on the connector that goes into the g60 clocks (suppose the 16v would be the same) tried to look on elsa win but it comes up with a screen thats says no data for this vehicle or something Quote Share this post Link to post Share on other sites
G60_Marc 0 Posted May 26, 2010 try this download/file.php?id=73899&mode=view Quote Share this post Link to post Share on other sites
waynos 0 Posted May 26, 2010 mate, you are the man! many thanks Quote Share this post Link to post Share on other sites
krnau 0 Posted May 27, 2010 Thanks to Dennis@CCC this if for after year 1991 http://members.shaw.ca/vr6_corrado/Corrado-Cluster.pdf this for 1989-1990 http://members.shaw.ca/vr6_corrado/Corrado-Cluster-1990.pdf Quote Share this post Link to post Share on other sites
waynos 0 Posted May 27, 2010 Cheers i forgot i could have looked in the bentley manual. I have one more question about the actual connector. Which pin is number 1 etc? Quote Share this post Link to post Share on other sites
waynos 0 Posted May 28, 2010 Think ive worked it out. On my g60 clocks there isnt anything but on a set of 16v clocks they are. As long as they are the same Ill b fine Quote Share this post Link to post Share on other sites
krnau 0 Posted May 28, 2010 Cheers i forgot i could have looked in the bentley manual. I have one more question about the actual connector. Which pin is number 1 etc? pins are labelled on the inside of the plug, you have to remove its cover Quote Share this post Link to post Share on other sites
