A5 VRX 0 Posted July 25, 2010 Just been doing the coilovers on the rear of the VR, thought the bolts and collars would be interchangable but no! Where do you get nuts and the other bits to finish the top of the rears off? AJ Quote Share this post Link to post Share on other sites
KADVR6 0 Posted July 25, 2010 give demon tweeks a shout, if not try g-werkes Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted July 25, 2010 Had this same issue myself. I went to Lark speed and they were fcking useless. In the end i got some from a local DIY shop. If you search for 'Koni top mount nuts' or something like that and look for it as me as author, there should be a thread. If you have no luck, let me know i can get some for you and post them on. Quote Share this post Link to post Share on other sites
A5 VRX 0 Posted July 25, 2010 Cheers, thought i was nearly there then the metal collars and 2 nuts are to small!! Oh the joys! AJ Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 25, 2010 Yeah, they are 1mm bigger - The bits come in the Kit so I'd contact Koni or a supplier. You will also need to drill out the top plates too although I'd buy new ones and also wax them. Quote Share this post Link to post Share on other sites
A5 VRX 0 Posted July 25, 2010 Where can you buy the correct plates? Coilovers are 2nd hand thats why they didn't have the nuts/plates Thanks Adam Quote Share this post Link to post Share on other sites
A5 VRX 0 Posted July 26, 2010 Does anyone know the size of the nut i need, M10, M12, M14 etc Thanks Quote Share this post Link to post Share on other sites
A5 VRX 0 Posted July 26, 2010 Are these the correct ones? http://cgi.ebay.co.uk/M12-x1-25-mm-FINE-THREAD-R-Hand-Half-Nuts-rose-joint-X5_W0QQitemZ160414703298QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item2559761ec2 Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted July 26, 2010 Possibly. Its the thread pitch that matters too. 1.25 sounds about right. Let me see if i can find the topics when i asked the same question. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted July 26, 2010 CAAAAACHINNNNNG!!!! Here you go mate, just for confirmation on the size - viewtopic.php?f=23&t=74986&p=884081&hilit=top+mount+nuts#p884081 Quote Share this post Link to post Share on other sites
A5 VRX 0 Posted July 26, 2010 We deal with Bapp at work! On a 2 week holiday shutdown though. Thanks for all you help mate, hopefully get the gal rolling tomorrow, just need to drill the top plates now, Thanks alot Adam Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted July 27, 2010 No problem Adam, hope you get it sorted fast! Gaz Quote Share this post Link to post Share on other sites
