jimbobbalooba 0 Posted August 3, 2010 Hi All, I have a '93 Corrado VR6 and I'm putting back on the Anti Roll Bar. I can't remember which way up it goes and even though I've taken loads of photos throughout the project, I can't seem to find one which actually helps me. I have the ARB which uses the traditional brass droplinks... http://vr6corrado.wordpress.com/2010/08/03/whats-more-annoying/ If ANYONE can provide a clear picture or instruction it would be most appreciated. Many thanks Jim Quote Share this post Link to post Share on other sites
beastie4126 0 Posted August 3, 2010 Having done this myself I know how annoying it is, lay time I removed it I put a line of tippex accross the top. The arb should be above the wishbone when installed with the middle loop/bend pointing down. Links should be above wishbone as well. Can take a pic later if stuck Quote Share this post Link to post Share on other sites
jimbobbalooba 0 Posted August 3, 2010 beastie4126 said: Having done this myself I know how annoying it is, lay time I removed it I put a line of tippex accross the top. The arb should be above the wishbone when installed with the middle loop/bend pointing down. Links should be above wishbone as well. Can take a pic later if stuck Thank you so much. I'll take a pic to demonstrate our frustrations!! Jim Quote Share this post Link to post Share on other sites
