CIPO
Thudding noise
Kinda hard to describe this but i'll give it a go.
There's a dull thudding noise coming from the front. At first i thought i had a puncture but i hadn't. Usually very subtle but can be louder.
Happens when out of gear too(coasting). Had wheel bearing replaced as precaution but me thinks its from that sort of area.
Has been there for months & is getting progressively worse............
Any ideas or anyone suffered similar?
Cheers.
Presumably if you know it's not a puncture, you also know your tyre pressures are good?
