Topaz2008
G60 Knife edged Throttle Problems
Today I fitted a knife edge throttle and polished inlet to my G60. It started fine but I have idle problems.
With the idle screw screwed right in I am running at 1000RPM increasing to 1100RPM when hot. It also hunts between these to figures sometimes. The car is SORN and there is only a small car park where it is stored so no power runs yet :-(
Any ideas???
Worth checking for vacuum leaks or disconnected pipes in the areas where you were working.
