sleeper16 0 Posted February 23, 2011 hi, my rear spoiler is not working on speed just the switch so i started to have a dig about at the fusebox after reading on here about a common cable being unplugged. unfortuantly i found a few and have little to no idea what they are for. please could someone identify them and give any hints as to where they go.they are all the single cable plugs so top of fusebox? I Have: A green plug with black cable blue stripe (spoiler control module?) A yellow plug with yellow cable and black stripe A red plug with red cable and brown stripe A blue plug with red cable and white stripe A blue SOCKET with white cable blue stripe Here are a few pictures to help cheers Quote Share this post Link to post Share on other sites
floppyman 0 Posted February 23, 2011 there is some plugs that are allways disconnected... as far i can remember at least the red yellow and blue plugs might be just extras... like original extras (imobilizer, alarm)... i think your problem is not going to be in the relay box Quote Share this post Link to post Share on other sites
sleeper16 0 Posted February 23, 2011 cheers! can anyone confirm this? if thats the case ill stick fusebox back up n underdash trays back in after three weeks of them flying around on the backseat! cheers Quote Share this post Link to post Share on other sites
quicky1980 0 Posted February 23, 2011 sleeper16, there are plenty of topics on this already. I had trouble with mine recently so did a search on here and got the answer. give that a try Has it never worked? have you messed with the wires etc My issue turned out to be an incorrect wire being connected to the speedo signal terminal... Quote Share this post Link to post Share on other sites
sleeper16 0 Posted February 23, 2011 sleeper16, there are plenty of topics on this already. I had trouble with mine recently so did a search on here and got the answer. give that a try Has it never worked? have you messed with the wires etc My issue turned out to be an incorrect wire being connected to the speedo signal terminal... has what ever worked? the spoiler? only had the car about a month it works on switch but not on auto. not botherd about that really for this post. iv have read about common problems so will check them. this post is about the cables at fusebox if they are extras and are not required then ill be happy n stick the underdash back together. spoiler problem still has alot to check out yet its just when looking at one possible cause i found new problems(nothing new there!) cheers Quote Share this post Link to post Share on other sites
RW1 0 Posted February 23, 2011 Here's a couple of useful photos of an unmolested factory standard Link . Quote Share this post Link to post Share on other sites
sleeper16 0 Posted February 24, 2011 cool cheers thats three if the plugs taken care of! anyone know what the blue plug and green plug are for? from your photos rw it looks as if the blue one goes to the fusebox just to the left of the 53 relay can just see a blue plug there. cheers Quote Share this post Link to post Share on other sites
sleeper16 0 Posted February 24, 2011 scratch that just seen the blue plug with red n white cable. so just green plug with black cable blue stripe. and yellow plug with yellow cable black stripe(diffrent to the yellow plug in your photo) Quote Share this post Link to post Share on other sites
