KADVR6
bloody wipers
had a problem with my wipers since i had the car, they will not go onto intermittent, and will also do not park properly as i have to time it just right on the stalk to get them to rest at the bottom of the windscreen.
changed the fuse and the relay, and also cleaned up the connectors on the stalk and they are still not working properly.
any ideas please.
karl
Jumping at straws here but from the dim recesses of my memory, is there not a contact in the wiper motor, under the cover plate that controls where the motor stops. Maybe worth a look. Might be totally wrong though.
mine was doing this on and off for about a year, then the contacts in the arm shorted and started pooring out smoke.
new arm and everything was working again. nick somebody elses for half an hour and see if it cures it.
