car1
few bits
Hi all,
i need both headlight bulb covers that screw on or twist on
also both front plastic protectors that cover the back of the headlights and screw to the body
passenger side front plastic piece that runs on top of the front door card and pin as mine is cracked.
hope theres enough information,
Hi i can help with the h/lamp protectors & if it's the long plastic strip that the door card slots into & hold the inner window seal,i have that too.i will confirm the h/lamp bulb covers.
Hi, have sorted all the parts you need . x4 bulb covers ,x1 passenger door trim strip & the drivers side headlamp trim.There isnt one on the passenger side. have checked my other corrado & there isnt one on that either.So with the postage how does 20 pounds sound.
let me know, rod
