Julien
Julien's G60 Rado - 16v Eaton M90 inside
Hi everyone,
As I couldn't more to ride a MK4 TDI, I decided to buy a rado for 4 months now.
So it's a 91' G60 with 137000Km.
It has all the classical options.
Unfortunately the day I bought it, I had an engine problem.
A very strong rattling came from the bottom and everybody guess the following
The cause was a seal of the compressor that was not in the good place.
Presently there are :
ENGINE :
- 16v gearbox
- JABBA stage 2
- 68mm pulley
- Outlet RS kit
- By-pass group A
- W6DPO
- SKF High Flow water pump
- FPR porsche 944
- VENAIR hoses kit
- KW suspension
INTERIOR :
- HI-SPEC phantom oil temp gauge/oil pressure gauge/compressor pressure gauge
- VR6 Intérior
EXTERIOR :
- VR6 front bumper
- VR6 hood
- Red/Crystal tail light
After a check of the engine, I had to change the crank so I decided to build a 16VG60 but after a moment, Idecided to replace the G60 by a M90 Eaton. I'm still building it and will soon post pictures of the parts...
Here are pics of the car few days before I got it :
nice clean bay, be good to see another supercharged 16v on the site too. keep us updated on the build.
Thanks.
I will update it as one goes along
So to check where does the rattling came from exactly I opened the engine block. As you can see, there was so much metal shaving...
The corrado during the operation
Then the block where you can see that the crankshaft is marked
Look at those con rod bearings...
The metal shaving...
As I wanted to do a 16VG60, I decided to buy a 16v KR engine to fully rebuild
My rado during the disambling of the engine
The springs and valves of the cylinder head
and a lot of parts :lol:
Then I painted the coolant reservoir.
