Fanjita
Vr6 2.9 ABV engine *sold*
Very old thread bump!
I still have this in my garage and really need the space now. Any takers?
Make me an offer!
I think i did the major stuff about 3 months before it went off the road. A good service would be ideal before its fitted though, I wouldn't fit any used engine without at least an oil change and check the plugs? Plugs aren't too old iirc but ill check the receipts.
No i would fit it without a service either but its not for fitting straight away, mainly spares and long term rebuild for when mine conks out eventually
other than block and internals, what else comes with it?
is it obd1 or obd2?
cheers
Edited by p0l1wrath
As per the initial post but seeing as you missed it
"This will include intake manifold, coilpack, spark plugs (plenty of life left), ht leads (nearly new), injectors (ultrasonically cleaned) and rail"
---------- Post added at 4:10 PM ---------- Previous post was at 4:09 PM ----------
It's a vr6 from a corrado so obd 1
Is that still palletted Fanjita? I know I said it's take it, but not managed to sort somewhere to keep it as it'll not fit in my flat cellar on a pallet and I have no garage! Anyway, if that's palleted i'll def take it even if I have to keep it in the van for a bit! Just don't tell my other half :p
At the moment it's sat on wooden blocks but it's right next to a crane and an empty pallet so I can get it on the pallet for you!
Just let me know how you want me to arrange it. Cheers
