Corradochris16v
Power steering pipe
Hi need the power steering pipe that bolts on to the pump and attaches to the top of the steering rack for a 1.816v I'll post a pic up later of the exact pipe am after.
Am also after the trim that fits over the wiper motor basically the lower part off the scuttle cover. I already have the passenger side so presume there should be a cover for the drivers side?
I took some pics to make it easier.
mk2 golf 16v will have the same PAS hose IIRC, so that might help you out - try ebay.
the part of trim you're looking for is called the "rain tray" - stops rainwater getting into blower motor and the ecu! useful :-)
Jon.
Jon.
I think you misunderstood there, I think he's on about the scuttle cover the corrado never had, i.e. what's in the pic but on the driver's side, or perhaps just the passat small cover that goes over just the motor itself.
[ATTACH=CONFIG]68358[/ATTACH][ATTACH=CONFIG]68359[/ATTACH]
Are these the pipes you mean
[ATTACH=CONFIG]68360[/ATTACH] i also have this cover think its a modified mk4-5 one fit this tomorrow
