bigben
clutch went
was drivin alond at the weekend and each time i changed gear i had to push the pedal further down!! andyone any idea what is leakin??
sounds like the slave cylinder is giving way... :|
Check your brake fluid level (the reservoir is shared between clutch and brakes) to make sure it's not getting too low, and then bleed the clutch slave cylinder (exactly the same way you'd do a brake caliper) If this improves things, then it's almost certainly time for a new slave... :?
Good luck... 8)
