will 2
abs wiring loom
i have a 94 16v 2.0 and was wondering if i could change the abs loom to a later spec one , the one i have is the one with the 2 conectors going into the abs warning light in the dash, i am hoping that the other end is the same on both looms
thanks in advance
I have a 95 VR6 and there are two connectors going into the ABS light on that iirc - you sure you haven't got the later type?
the conectors that are on my car is by the sound of it the same as your with the 2 plugs going into the abs light , i have bought a loom that has 1 conector either end ( to go with the new abs light i have ) , so i am hopeing that the end that fits into the fusebox/relay side is the same as the one thats on the car now
