nia573
Auto electrical testers & sparkplug thread repair tool
Have some handy test leads for sale
1st type are for connecting a multimeter to the fusebox:
Draper Expert Fusebox adapter test leads
Either for 3mm mini fuse blades or 5mm maxi fuse blades
For testing & measuring current straight from the fusebox.
Plug the lead directly into fuse socket recess & while being tested the fuse is inserted into the side of the tester housing to maintain circuit protection
Avoids the awkward process of pushing test probes into the fuse sockets & making temporary connections
Leads are approx 750mm long
These are £6.50 each posted 2nd class recorded
2nd are stand alone testers that plug into fusebox directly to measure current drain
(Ideal if you don’t have a multimeter)
Draper 3mm mini fuse or 5 mm maxi fuse Blade Automotive tester
Expert Quality, for rapid and accurate amperage testing.
12-48V/20A AC/DC measuring range.
Liquid Crystal Display screen shows readings.
Plugs directly into fuse socket recess.
Supplied with cable 750mm long.
Uses 12V-A23 battery (supplied).
These are £15.50 posted each 2nd class recorded
Expert Spark Plug Thread Repair and Restoring Tool
M14 X 1.25mm
Expert Quality, for the repair of spark plug threads. Allows thread repair from the bottom (not the top) so that swarf & debris wont fall back into the threaded hole, as it would with a standard tap
Insert the tool through the thread
Expand until it is located
Carefully wind out tool to reform damaged thread
Satin chrome plated tool steel hardened and tempered
£15 posted 2nd class recorded
All items are new & unused
Zag High top Toolbox
14.5” 405mm long
With tote tray inside
Hardly used
Bit dusty on the outside
£12 posted
Some top quality gloves
These are meant for horticultural/gardening use but are v good quality & could be used for other things
Soft Touch Gloves
Gents size
Leather & Nylon Backs with Velcro fastening cuff
£12 posted
Dry TouchGloves
Ladies size
Treated soft leather
£12.00 Posted
Winter Touch Gloves
Soft leather & Nylon with Thinsulate lining
Ladies size
£13.00 Posted
Mike
Bangor N Wales
[email protected]
Edited by nia573
Toolbox & gloves added
