VEEDUBBED 0 Posted April 17, 2013 Right then, got a few problems regarding my ignition switch cowl that fell to bits. Basic fact is that the fekkers are NLA anywhere so i've managed to source 1 off a '95 model. Now i also need the compleat wiper/indicator/mfa stalks aswell.. SO what is involved in retro fitting this lot onto a '92 model corrado?? Are the plugs the same? do the 3 fixing screws have their holes in the same place? Do the stalks have to be Corrado specific or would the mk3 golf ones fit? I've got a MOMO steering boss fitted, will the indicators still self cancel? Anyone who's done this conversion please chime in and yes i've searched but got bugger all. CHEERS!!! Quote Share this post Link to post Share on other sites
Stonejag 10 Posted April 17, 2013 The holes must be in the same places, as you can use old-style indicators on a late car if required. I assume this means the plugs are the same also. You can definitely use Mk3 parts, my cruise stalk came off a Passat... Self-cancel relies on having the rectangular protrusion from the back of the boss - if your boss has one of these, make sure it is to the right side as you look at the steering wheel. Might be easiest to fit the wheel to the boss after the boss is installed to get the alignment closer - though it's not that critical. Stone Quote Share this post Link to post Share on other sites
