G60 CS 0 Posted May 9, 2013 I have a 92 G60 Corrado My front wipers have just started only working on high speed setting. I've changed the motor for a known good one, tested relay 18 by pulling it , had no wipers at all then , the front wipers I believe share a fuse with the screen wash which is working so am I right in thinking I need a new stalk ? Quote Share this post Link to post Share on other sites
KIPVW 0 Posted May 9, 2013 May be worth checking where the wiring plugs into the stalk itself too before replacing with a little WD40 or something. If it is a late style stalk i have one on my breaking thread too :) Quote Share this post Link to post Share on other sites
Jim 1 Posted May 9, 2013 Think it's the relay if it'll only work on top speed. You need to get a new relay or one from a breaker. Had the same myself but just reseating it was enough to make it behave again! :) Quote Share this post Link to post Share on other sites
bully 10 Posted May 9, 2013 i had this issue but it was wipers wouldn't go off lol took relay out shook it and put it back in.. worked fine lol Quote Share this post Link to post Share on other sites
KIPVW 0 Posted May 9, 2013 i had this issue but it was wipers wouldn't go off lol took relay out shook it and put it back in.. worked fine lol :lol: Gotta love Corrados Quote Share this post Link to post Share on other sites
G60 CS 0 Posted May 9, 2013 (edited) Thanks for the the replies Kip great to meet you at Stanford, cheers for the pass had a great day ;) I took out relay 18, wipers didn't work at all without it in, surely if the relay had failed the wipers would still work on the top speed ? I have a spare ill check and try it if I have . I also have some electrical contact spray, will give that a go too. I'm pretty sure it'll end up being the stalk but its an early one I'm after. Kip do you have a late nearside fog on your breaker ? Edited May 10, 2013 by G60 CS Quote Share this post Link to post Share on other sites
Jim 1 Posted May 10, 2013 Thanks for the the replies Kip great to meet you at Stanford, cheers for the pass had a great day ;) I took out relay 18, wipers didn't work at all without it in, surely if the relay had failed the wipers would still work on the top speed ? I have a spare ill check and try it if I have . I also have some electrical contact spray, will give that a go too. I'm pretty sure it'll end up being the stalk but its an early one I'm after. Kip do you have a late nearside fog on your breaker ? Well I'm still willing to bet my money on it being the relay that's at fault...... :) Quote Share this post Link to post Share on other sites
KIPVW 0 Posted May 10, 2013 Fogs went a while ago i'm afraid. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted May 10, 2013 If its the relay, you might want to update it by fitting one of those programmable wiper relays. So that you can change timing of the intermittent wipe, a very useful feature and its just a plug and play mod. I have a standard working relay, if you need it. Quote Share this post Link to post Share on other sites
G60 CS 0 Posted May 11, 2013 Cheers Sankey I was looking at those programmable ones, anyone got a part number or better still a Bosch number ? Quote Share this post Link to post Share on other sites
Wullie 1 Posted May 11, 2013 Relay 99, available from lots of VAG group cars in any scrapyard for about £1. Quote Share this post Link to post Share on other sites
G60 CS 0 Posted May 11, 2013 Fogs went a while ago i'm afraid. Worth an ask :) ---------- Post added at 12:56 PM ---------- Previous post was at 12:50 PM ---------- Relay 99, available from lots of VAG group cars in any scrapyard for about £1. Wullie I did read it was relay 99 elsewhere but it said it was a direct replacement for relay 9 or 19 I think ? My car has relay 18 so wasnt sure it was compatable. Maybe I can get a secondhand one for a quid but I'd rather get new, i have a mate who works for a company supplying Bosch parts so I get them pretty cheap, last relay I bought was £17 at gsf but £3 off my mate. Buying new gives me a bit more piece of mind which being a a G60 owner is priceless lol Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted May 14, 2013 I bought a new relay from VW for £27, will dig the part number for you if you want. Quote Share this post Link to post Share on other sites
