daniboy1_2_3
G60 flywheel measurements
Hi there im on the lookout for a secondhand g60 flywheel. I wondered if anyone had access to the wear limit and original plate thickness dimensions please as I dont have a manual? Ive noticed a few for sale but wanted to check they were ok.
Edited by daniboy1_2_3
Hello mate,
VW Corrado G60 (6 bolt flywheel) face diameter 228mm 1989-1992 same as VR6 (but VR6 has 10 bolt flywheel) for 02A gearbox.
Corrado G60 gearbox code ATA 02A (1989 to 1990)
Corrado G60 gearbox code AYL 02A (1990 to 1992)
0.5mm run out limit I think is the most common for these flywheels,
as anymore could course clutch judder / vibration.
Not to sure what the wear limit is on these flywheels i.e thickness limit.
Check that flywheel face is flat and smooth and has no cracks or pitting in it (friction & heat damage)
Have a look at this link, loads of info on it http://www.myturbodiesel.com/1000q/clutch-kit-FAQ-VW-Audi.htm#flywheel
Hope this helps.
Si
