Supercharged Junkie 0 Posted May 15, 2004 Hi I wonder if anyone could help me with some wire colours and diagrams for a 92 G60 Trying to fit a pro start push start button and the instruction are abit BLANK :x Here`s what i need to know:- 1. Remove the ignition light wire at the point it is connected to the alternator (Which wire is the ignition light ?) 2. Remove the wire from the terminal on the starter motor solenoid - WTF does this mean ? 3. Locate the terminal on the back of the ignition switch marked 1G or 15, There is usually a white wire connected to this terminal (is this true ?) Believe it or not but i only got this kit because it said it was easy to install :mad: Any help would be appreciated :) Cheers Ian Quote Share this post Link to post Share on other sites
Supercharged Junkie 0 Posted May 16, 2004 OK i guess no-one knows anything :mad: Kinda figured out 1 & 3 just need to know what wire they mean coming off the starter motor solenoid :?: COME ON GUYS i know some of you have push starters, Throw us a fecking bone here :lol: Cheers Ian Quote Share this post Link to post Share on other sites
