clumpy1
1.8 16v breaking (Early car)
Hi folk's I recently bought an Early 16v which I have ended up breaking due to rust/corrosion issues,I have kept alot of part's off the car as spare's for myself but do have some part's,I can't remember them all but if there is something you need just ask and I'll let you know if I have it. Thank's
Cylinder Head (look's in very good shape has new valve guide's) £50
Rear vw roundel(both part's) £8
Radiator Cover £8
Rear view Mirror £sold
1.8 16v ECU and Ignition Amp £35
Side Indicator wiring loom complete with scuttle gromet £10
C/L pump in cover with fixing strap and nut £20
Strut Top Cover's £5
Complete 16V fusebox £25
Early window switch's £10 each or £15 for the pair
Spoiler Control Module £15
16V Idle Control Module £15
Early Dash blank's (2 of) £3 each
Early Dash blank alarm light hole £3
Ashtray £5
Rear number plate light complete £sold
Seat lifter's both part's £8
Interior door triangle's perfect with foam £10
Headlight rear bulb cover's £5 pair
Rear ABS wheel sensor (new in bag) £20
Brand New 1.8 16v Plug lead's,dizzy cap,rotor arm and coil £75
1.8 16v Distributor known working £35
All Price's plus postage.
Edited by clumpy1
Hello,
I will take your £10 Rear numberplate light with bulb holder if that's ok.
If you can let me know the postage to my address and let me know how you want me to make payment I will transfer the money. I have sent you a pm which gives you my address.
Chris
I think so somewhere mate they weren't standard though. I'm back at work 2moro will try and confirm what they are.
Do you have the two air duct panel things that attach to ether end of the splitter and connect to the wheel arch liners?
Its the flat ones that are attached to the splitter and arch liners.. They are normally either wrecked or missing on most Corrados..
How much would you sell the ECU, ignition amplifier, distributor and the ignition loom for?
Thanks Jordan
Hello, I am looking for the driver and passenger side seat belt receiver buckles that bolt to the seats. I would need them shipped to the U.S. if you have them and could please do that. Please let me know asap. Thanks.
I do have 1 spare door handle not totally sure if it's driver or passenger though I'll try and find out over the wkend got other stuff to sort on the daily first I'll do my best for you.
Sorry Simon you will have to be a bit more specific mate front/rear possibly a pic I am not a Corrado Guru mate I am still a bit of a newbie.
