sankysvr6
G60 Charger bracket O ring
Part number 049 127 311
This is the O ring the fits behind the support bracket that bolts on to the engine block, which holds the supercharger.
They are made out of Viton rubber which has an operating temp of -25C to +200C. So ideally suited for this application.
This is not a genuine item, as they are obsolete now. But I believe these are equivalent to the original if not better.
£1.50 Posted first class to your door.
Edited by sankysvr6
