will87cab
Electric window loom
Hi I'm after a complete early electric window wiring loom. Needs to be complete from fuse box to control module to switches n motors don't need any of the motors, switches or control module just the wiring must be from a early car with switches in the door cards.
Thanks
Will
Can probably help with this.
You are basically after both door looms then essential and the main one for the fusebox to the control module.
There are other wires as part of both looms so they will come whole as they are, assuming i can find all you need.
Yeah that's right. I think there is some speaker wires and some stuff to do with Central locking
taped up together
