p0l1wrath
Track rod (not ends) removal
Hello
Just wondered how the track rods are removed from the steering rack, i know it seems to be a bit of a pig to do
I just want to know do they screw in and out at the rack end yeh? If so is it normal thread?
Will i lose any steering fluid whilst i take them out.
hmmm, still struggling to understand how they are actually in the rack?
im getting on with it tonight after work, will i soon understand once im under there?
Here is a picture of it.
It just screws into the rack.
Remove boot, use special tool, crow foot or possibly large spanner if there is enough room to undo and its off.
The 'correct' way is to hold the rack in a vice with it off the car, however most garages will just use a quick track rod removal tool that goes over the rod and takes 5 minutes to do the job, I've used these several times with no issue and yes the rod just unscrews but can be tight due to threadlock
