nutter driver 0 Posted July 23, 2015 Guys and gals, My better half was on her way home tonight, wound the window down (drivers side) to the bottom, and then discovered it won't go back up. Passenger side works fine, clicking noise when you operate the switch for the drivers side. I've popped the dooryard off and carefully removed the membrane, the window moves freely in its runners, without any resistance. I've checked across the connector for the motor itself with a multimeter and I'm seeing 12v when the switch is operated, so I'm assuming the motor is goosed? Can anyone confirm if my logic is sound, or if I'm missing anything? Assuming the motor is dead, then I'm guessing it's a drill out the rivets to replace it job whilst propping up the window with a random piece of wood in the mean time?? Cheers, Pete Quote Share this post Link to post Share on other sites
