marks2 0 Posted October 27, 2016 (edited) Bit of a long shot but here goes.... I have a complete brake kit for a 4 stud hub consisting of: - Porsche 996 front calliper2 with modified SEAT carriers & all bolts to mount on the corrado hub - 305mm Ibiza Cupra-R discs - HEL performance braided hoses The discs and pads have plenty of life left in them. I'm looking for a performance conversion to fit under the std G60 BBS alloy. Hi-Spec / Tarox / AP etc. I'm not really interested in floating caliper setup. Let me know if you have something and are interested in doing a deal. Edited November 8, 2016 by marks2 Quote Share this post Link to post Share on other sites
g0ldf1ng3r 14 Posted November 8, 2016 i think your issue may be due to stud pattern the 'majority' of people i believe would want bigger brakes on VR though G60's are 4 stud i guess so maybe they might like them Quote Share this post Link to post Share on other sites
marks2 0 Posted November 8, 2016 i think your issue may be due to stud pattern the 'majority' of people i believe would want bigger brakes on VR though G60's are 4 stud i guess so maybe they might like them The forum does appear to be predominantly VR's. Not sure if the discs can be drilled for the 5 stud hub? Any idea if the centre bore is the same? Quote Share this post Link to post Share on other sites
g0ldf1ng3r 14 Posted November 8, 2016 The forum does appear to be predominantly VR's. Not sure if the discs can be drilled for the 5 stud hub? Any idea if the centre bore is the same? it could be that the VR's are more common than the g60's & not much need for big brakes on a 16v (ie another 4 stud) i doubt redrilling would be preferable only option i could potentially see is if the calipers could be used with alternative carriers so as to fit a VR with other discs Quote Share this post Link to post Share on other sites
MZpog 10 Posted November 8, 2016 not much need for big brakes on a 16v (ie another 4 stud) I found the need and upgraded to the 280mm G60 setup. I'd upgrade again but only if they fit under my ETA Beta Lucy's which these obviously won't. Quote Share this post Link to post Share on other sites
