Zyclamvw-scirocco 10 Posted May 31, 2017 hi guys whats the procedure for removing the dash in a corrado? I'm actually looking to take out the fresh air and fan system from behind the dash, but figure you need to get the dash out first? it all looks fairly straightforward , up to the nuts (any idea about size?) that are right up by the windscreen, how do you get them out with the screen still in place?! any hints or shortcuts would be greatly appreciated cheers Quote Share this post Link to post Share on other sites
Jim 1 Posted May 31, 2017 A forum member put together a fairly comprehensive guide on the heater matrix replacement.. the pics seem to have gone AWOL but the description is pretty good. http://the-corrado.net/showthread.php?45452-Replacing-the-heater-matrix-non-canada-style-max-pics I've got a copy of it I can upload with (most) pictures in it if it'd be of use! It's not too bad to be honest - just time consuming! Those screws you talk about are in the scuttle panel - a bit of a fiddle to access, but no-where near the screen and the screen doesn't need to be removed or anything :) Quote Share this post Link to post Share on other sites
