baff 10 Posted January 24, 2019 Hi guys, I have a newbie question Does the corrado 2.0 16v 9A has a ecu vacuum line? I have some idle problems, cleaned the ISV, and after looking thru the forum I saw that the ecu vacuum line for G60 and VR6 is sometimes the issue. I looked at my ECU and I just don't seem to find one. Thank's for the support! Quote Share this post Link to post Share on other sites
baff 10 Posted March 13, 2019 Ok! So... this is what the back of my ECU looks [ATTACH=CONFIG]96534[/ATTACH] Should I plug the ECU vacuum in this hole? Is it supposed to have a plug of some sort? Thanks! Quote Share this post Link to post Share on other sites
vw rule 19 Posted March 16, 2019 Hello there, I don't think the 2.0 16v has a vacuum hose going to the ECU, the G60 has so the ECU can measure the vacuum advance or the boost. But like I say the 1.8 16v and 2.0 16v Corrado's don't normally have a vacuum hose to the ECU. There sometimes is a black or green plastic/rubber bung / plug, in the back of the ECU but not always, i.e to seal the hole you are showing in your photo. Si Quote Share this post Link to post Share on other sites
baff 10 Posted March 17, 2019 Thank you @vw rule! Quote Share this post Link to post Share on other sites
