    3,795
Heater Matrix - Foam Gaskets - Advice needed.
Yabble Dabble
Having spent a ridiculous 16 hours sorting Heater Matrix - including cleaning out air intakes of water, glycol and K-Seal - found that I still need to replace the Thermal Resistor to get fully functioning fan speeds.
I now need to identify a source for the persihed foam gaskets that covered the doors to the Heater Matrix Box to ensure that the air flow is suitably directed.
I have identified that the Foam Gaskets for the "doors" in the Heater Matrix Box have perished and I need to source some new material.
Does anyone have half a clue what and where I can source these little gems of technology ?
Are they something only VW can supply or should I look for them through a particular agency like RAM Gaskets http://www.ramgaskets.com/gaskets/foam-gaskets/ ?
Are the foam gaskets made from Silicone, Nitrile, Neoprene, EPDM, Polyethylene, Viton ?
Eager to find out so that I can fit - less than 16 hours this time - before the end of the short UK summer in time to heat my journeys.
Very much looking forward to a little less time with my head pushing the clutch pedal to it's fullest extend while I try to manipulate the metal spring clip onto the Heater Matrix Box on the driver side of the box with a screwdriver or something !!
Many thanks for kind replies.
1 Comment
Is anyone able to offer advice or help ... I still have no means of directing the airflow through my ventilation system.
Many thanks to the experts of you out there who will give me an idea as I am still flummoxed by this and know that to fit replacements will take some doing.
