bluester
34 -
0 NeutralAbout bluester
ESSEX
AUTOMOTIVE
ok guys replaced heater matrix, got rid of bypass valves car heats up lovely heater is ROASTIN . only thing is screen gets oily residue while heater is on car seems to get a bit steamy inside, ive just read a post about washing new matrix to remove protective coating(which i didnt do) could this be the cause of my symptoms or i have i put i a "new" damaged matrix. help!!!
found out my 16v is gushing out oil from the area of the oil filter housing, any one know if there is a gasket around there that might have gone or ant ideas what it could be ?
hi all im after some help basicly the heater in my 16v is pants it gives out very little if any heat. im not overly technical but ill give it a go where should i start checkin. i think thermostat is worrkin ok but i have ordered a new one. the control flaps seem to be changing , it does have two bypass valves ( one metal one plastic) ive heard about drillin out these valves??? should i flush the matrix or just replace it?? any advice u guys can give would be appreciated coz it aint much fun drivin a cold corrado. :(
decided to try fixed pulley 027121031 cost £18 can anyone think if it will cause any damage ? must admit it is really nice to have my c not sounding like a rattling bag o bolts.
my pulley on way out aswell :( has anyone sorted out what is needed & part numbers to do this mod i would be really interested thanks
Door handle repair kit..........THEY ARE NOW AVAILABLE
bluester replied to daves16v's topic in Suppliers Forum
BRILLIANT! recieved my repair kits easy to fit (about 15 mins) nicely made,alot of thought gone into the design,works perfectly,dave 16v your a legend.cheers dude :D -
hi dave 16v the inevitable has just happened drivers door dont open :( can u tell me if your fabulous repair kit is still available and how do i get my hands on a set, cheers -
hi guys on my 16v ive found the source of a rattle its a guide pulley near the water pump ithink it should have brass discs inside itbecause i found part of one when i took it apart. does anyone know if you can buy the rings seperate or do you have to buy the whole pulley
PhilT the mask from scream i see what you mean :lol:
thanks for the comments guys i didnt expect it would be to many peoples taste i appreciate your honesty, ive still got a few changes to make to it and even then it might not stay on if it dosent look right im not a total barbarian, the comment about "thick paint" was ok coz it aint finished yet, but "corsa brigade" cut deep ive been a dub head all my driving life, im just prepaired to try something a bit different
hi guys have changed the front end of my valver a bit and was wondering what you lot think, its not finished yet but you get the picture
mine does the same replaced the water pump it cured it a bit but noticed there is a pulley (i think its a guide pulley) with a brass bearing that rattles about, maybe check that
a few pics of before, during, and after
Ice White Socks, did u get them from gpc ?
hi all can anyone tell me the best place to get 2 new roof gutter rubbers are they a main dealer part only :?:
