Serial
196 -
0 NeutralAbout Serial
Regular
- Birthday 07/12/1980
London
Software Engineer
Serial started following VR6 / Corrado parts on eBay, VR6 Engine Parts, K&N, Manifold, TB, MAF, ISV, ECU, Loom, Early steering wheel cowl, Short in engine loom - need replacement and and 7 others
For sale as a non runner - Bordeaux Pearl Corrado VR6 with OBD2 conversion. Here are some photos of the car: http://www.flickr.com/photos/93026755@N05/ Unfortunately I will have to let my VR6 go. I've owned it since 2007 and made a whole load of improvements to it including a complete engine rebuild, which has annoyingly just failed on me. I haven't got the time or enthusiasm left to rebuild it a second time so hopefully someone can buy it off me and either donate the parts to other cars in need, or replace the engine and keep L25 NUG going a bit longer! Bodywork, carpets and grey cloth interior are in excellent condition. Sunroof tilts and slides, refurbished 2007. Electric windows in good working order. Forgot to add, the spoiler works perfectly, raises and lowers at 45mph. 288 front brake upgrades done 2011. Koni coilover suspension fitted by Stealth in 2008, in excellent condition. Rear beam powder coated and refurbished with new bearings etc. Rear subframe refurbished, new bushes, powder coated. Wishbones, bottom ball joints, track rod ends all refurbished, new bushes and powder coated. 2011 Milltek stainless steel exhaust. OBD2 installed 2012, was running beautifully until water got into the multi-way engine plug and shorted it out, so will need a new loom or new connector. Engine rebuild 2009 - ARP main, crank and head bolts, Wiseco forged aluminium pistons, new bottom & piston bearings, new seals all round. Compresson on the cylinders is >190psi except for cylinder 6 which is ~100 dry, 130 wet. I suspect a worn/blown piston ring or cracked piston. Head work done by Impulse developments in Rochdale, all new valves, steam cleaned and repainted. Radiator replaced 2008 Toad Ai606 Cat #1 alarm with full closure, 2 key fobs. Headlight relay loom fitted. Spare wheel & tyre in new condition, jack and wheel wrench. Standard 15" speedlines in good condition, with four very good Uniroyal Rainsport tyres, approx 5000 miles wear. The recent suspension and brakes work made this car drive beautifully, very smooth and surprisingly comfortable ride considering the coilover suspension. I was getting a realistic 35mpg from OBD2 (measured at the pump) before the bottom end blew. I have a number of other parts for it which I never got around to fitting, which I will include: clutch slave cylinder door handle repair kit (both sides) new window rollers (both sides) replacement oil pressure and temperature senders Steering column housing for fixed height steering wheel mod. Full set of engine plastics. I will also throw in any Corrado/VR6 specific tools I can find. (e.g. spark plug removal tool, coilover adjustment spanner etc) Loads of receipts, history, and MOT till April 2014. I'll keep the tax disc! Clocks all work and show ~150000 miles. Known faults: Non-runner - shorted/melted engine multi-way plug due to water ingress. Rest of the loom looks fine though. Low compression on cylinder 6 - suspect cracked piston or worn piston rings. Clutch difficult to disengage, suspect slave cylinder needs replacing (replacement supplied with the car) Passenger door lock needs fixing Heater control stuck on Windscreen mode. Horn doesn't work, suspect steering wheel slider contact. Heated mirrors don't work, or move. £975 cash, no px, very close offers considered. Collection from London SE3, you will have to tow away or bring a pickup truck...
Hi - I have a few Corrado parts available for sale. All can be collected from London SE3 or I can post at cost. Payment by cash on collection or PayPal gift. VR6 K&N filter - a few dings but no serious damage, includes a part-used cleaning kit £10 http://flic.kr/p/dTpN1M OBD1 5-pin MAF (wire type, non-OEM). £40 http://flic.kr/p/dTpMBe Intake pipe, no cracks, includes jubilee clips £15 http://flic.kr/p/dTvqWL OBD1 throttle body with recent OEM throttle position sensor £25 http://flic.kr/p/dTvqsm http://flic.kr/p/dTpKXn http://flic.kr/p/dTvopG http://flic.kr/p/dTvnz9 VR6 OBD1 ECU - Part Number 021 906 258 AG SOLD http://flic.kr/p/dTvn27 http://flic.kr/p/dTpGTx ISV, damper and associated pipework £25 http://flic.kr/p/dTvmgm OBD1 Engine Loom £25 http://flic.kr/p/dTvkSW Black powder-coated OBD1 inlet manifold, coating is in good condition with no marks. £45 http://flic.kr/p/dTvkvo http://flic.kr/p/dTvk7d http://flic.kr/p/dTpFae Non-adjustable steering wheel surround for early interior, both upper and lower parts. Brand new. £50 for both parts, no split. 535 953 516B http://flic.kr/p/dTpER2 http://flic.kr/p/dTpEsT http://flic.kr/p/dTviBC http://flic.kr/p/dTpDqV Click the links for images, can't get the forum image uploader to work. Thanks for looking.
How to fit / wire / install obd2
Serial replied to C488ADO's topic in [Archive] Wiki Submissions & Collaboration
OK - I'm most of the way through this conversion now, having got the OBD2 loom installed in the engine bay and connected up. The issue I'm having is that the fuel pump is not starting, so the engine won't fire. On the Corrado loom, Pin 3 of connector G1 (G1/3) is a yellow/blue wire that connects to Pin 6 of the ECU. This is the wire that energises the fuel pump relay. However on the Golf loom, this pin just has a short length of black wire (6") that doesn't go anywhere. If I switch the ignition on and ground this wire, then the fuel pump runs. I did some investigation and found that in the Golf loom, there is a yellow/blue wire, connected to pin 6 of the ECU that leads into the back of the fusebox, but this is terminated in a single yellow blade connector. I tried connecting this to the black wire that goes to G1/3 (so it's wired to the same pin on the ECU as the OBD1 system), however the fuel pump still fails to start. Just wondering if anyone else has had this same problem, and if so, how did you get around it? So close to getting this to work now! Any ideas appreciated... cheers, Tom. -
Hi, do you still have any of these parts available? I'd be interested in making an offer for the Ecu + loom + mani + throttle body + new lambda + 4 pin MAF if you do...
Hi, is this still available? Whereabouts are you for collection? Thanks, Tom
Sounds good - I'll PM you my details. Supercharged - that's good news. I'll investigate getting a new plug for the bay side of the loom. Cheers Tom
Pretty much all parts from Corrado VR6 available
Serial replied to paxman's topic in Cars for Breaking
Hi, how much for the engine loom? From the multi-way plug to all the sensors. Thanks, Tom -
How much would you be looking to sell it for? I'm after the whole OBD1 engine loom from the multi way plug to the various sensors.
