Neil VR6 0 Posted October 12, 2004 I have two guages mounted in a pod just in front of the gear stick, volt and boost. Whilst they look trick and are actually useful, they are a bit "Fast & Furious" in that they light up in 7 different colours and light the whole car up at night. They also dont remember your selected colour and come on red as their "default" setting. Hence I want some grown up guages, simple black, backlit jobs. I'll probably get some Tim ones or have a look on the web. When I get the new guages, can I literally plug them into the holes and connect the old wires up to the new guages or will I have to wire them all up again. The voltmeter is no problems as I could wire it up to a circuit in the dash. However, with the boost guage would I have to route a new sender through the bulhead etc or can I solder the sender wire from the old guage to the wire coming out the back of the new guage? Cheers Quote Share this post Link to post Share on other sites
Henny 0 Posted October 12, 2004 just about EVERY boost gauge I've seen use a tube to the back of the gauge to provide the vacuum/boost to it... You should be able to swap the gauges straight over if you buy some new ones to do the same things... 8) Quote Share this post Link to post Share on other sites
gibber 0 Posted October 12, 2004 As for gauges autometer ones go for silly cheep money on ebay, and a leagues ahead of tim! And I concur with Henny on the wiring/plumbing of the boost gauge. Quote Share this post Link to post Share on other sites
Henny 0 Posted October 12, 2004 only thing to watch out for Autometer gauges (and it caught me out! :oops: ) is that they're American and therefore use Imperial thread sizes etc... :roll: :evil: Shouldn't be a problem with what you want (volts + Boost) but be careful if you want to put in oil pressure or temp gauges too... :wink: Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted October 12, 2004 Thanks all. I phoned up a nice chap at http://www.gbdriver.co.uk and ordered some. They stock loads and I ended up with black faced Splitfire ones. He said they were reliable and they're a good looking guage, not too Max Power! Quote Share this post Link to post Share on other sites
pablo_vr6 0 Posted October 12, 2004 Ive had autometer carbon ones before - nice gauges :) Quote Share this post Link to post Share on other sites
