fleur322
auxillary water pump
just wondering if anyone knows how easy it is to change an aux water pump. VAG only quoted me 1/2 hour labour so can't be so hard.
Any help on doing the job would help as well. Am I best with the VAG part or the GSF. Not a big diff in price both about 70 quid
Thanks Linz
Easy peasy lemon squeezey......
Off with the cable tidy above the coilpack (6mm allen key will do it), disconnect and plug the water hoses to the aux pump, disconnect the wiring plug, remove the pump from it's rubber bondage clamp and then the reverse order for the new pump!
Run engine up to temp with leave expansion cap off the coolant tank to allow any air pockets to escape.
