Jim
What needs doing to your Corrado?
Ive done pretty much everything I can to my valver. Just needs:
This rusty holey bit on drivers front wing sorted.
Clear Repeaters (xmas)
3 slat grill (xmas)
Get in the boot and sort out the b83937d rattles.
New front pads, and hence disks.
The main issue is not having to sell the bugger to pay off the debts i accumulated by spending wildly on it.
Here's to staying in!
DF.
Plastic that runs along the bottom of the windscreen,
it needs 3or4 of those two piece clips,
Im sure nobody is surprised as thats 3 weeks of waiting for the phone call from the dealer
to say they are in,thats after me walking into check twice,he took me number !
And waxoyl again for winter,engine bay and underneath
Fixing a relay on the headlights and changing fuse holders to watertight ones.
I'll get the headlights done today
8)
Loads to do, fit 2.0L lump, do some mod under the bonnet, refurb rims, lower it more, get it resprayed, arches redone, new mirrors, sunroof, retrim/change seats, fit some ICE & maybe then I'll be happy.. :roll:
Ok in 4 mths since I have had the car.....
Done.
New Alternator, new front tyres, new fan, new fan switches, new water pump, new thermostat and housing, new temp senders, new supercharger, new Vibra-Tech engine mounts all round, new battery, clear oval side indicators, new timing belt, new charger pully, new pullies for everything, new water cap, oil filter, full oil change, and this was on a mint car, I would have hated to have brought a dodgey raddo :)
Now I know how to take the whole front end of the car apart and have a screw left over :wink:
All done by yours truly and must I say a massssssssssssssssiiiiiiiiiiiiiiiiiiivvvveee thanks to all thee royal supporters on here and G-Werks/PitStop for the charger. By the way Steve why are you called Liam on the PVW, Liam dont look anything like you? And I notice Darren is driving the White raddo in one of the pics :)
To do.
Headlight Loom, Lupo wipers, All round Koni Coil Overs, Passenger side slight door ding and respray for the door, rear lights M3, Red/Clear
Darren was driving the white Rado - trying to wring it out on the 2 mile straight as I gradually cruised past him.. was funny ;)
Fit VT engine mounts.
Fit new rims.
Fit sub.
Hide Corrado-related receipts from the missus.
Find beige door cards.
Test out new component speakers with a view to purchasing.
.......and most importantly of all ..... enjoy!!
Re-spray to tidy it up.
X-Flow Head
1.9L bottom end
Fianally fit the Golf IC
Charger re-build
Poss Toothed pulley kit
Fit new clutch
Look into Mk3 16v gearbox
to do:
-stop all rattles inside car
-get new leather front door cards (the preious owner cut holes in them for speakers that dont fit - muppets)
-fix my guage cluster lights (i cannot figure out why they are not working - worked fine in my other car.)
-replace side marker bulb
-install my solid front motor mount
-upgrade headlights either to european spec, golf rallye, or bmw e36's
-find a red vr6 hood or a nice carbon fiber one (to possibly do a light red coat over to give it a red transparent color)
-a full car respray
-get a hold of a golf rallye or huge FMIC (i decided against the BBM liquid to air kit because on hot days the air would be hot as hell)
-install all of my stereo equipment (kenwood mp3/cd player, boston speakers, 2 12 inch subs in the rear, 600w amp)
-possibly look into a 1.9 or 2.0 bottom end to swap in
thats really all i can think of as of right now. this is going to cost my right hand to pay for everything i need. =\
well continuing from the last list I made...
Get supercharger rebuilt
Stop exhaust blowing
Fit new windscreen seal - Repaired old one... it'll do for now
Fit new drivers door seal
Fix sunroof
Fix drivers door lock
Fit oil cooler
Change oil
Fit New Alarm
Build Sub Box - (need sub first) - although will need doing again when I get another sub.
Finish passenger door handle conversion
Spray passenger door
Fit new passenger door
Fit new handle to green driver door
Spray driver door
Fit new driver door
Spray sunroof
Replace sunroof seal
Machine and fit some wheel spacers
Fit new number plates
Fit later style fog/indicator lights
Fit Supercharger
Fit Boost Return Mod
Replace Air Filter – K&N 33-2029 from Motorsportworld.co.uk
Remove Air box Snorkel
Replace Spark Plugs – Bosch W5DPO
Do a compression test
Replace Engine Oil – Quantium Silver 10W40 from VW
Replace Gearbox Oil – Redline MT90
Spray Linkages at the Gearbox with WD40
Make new base board
Secure base board using Velcro
Put foam or soundproofing under base board and sub box
Secure sub box more firmly
Put foam under amp
Find squeaks and oil them
Find creaks and use sound proofing to get rid of them
Run cables under carpet
Die Head lining black
Fit new air freshener
The things in red are stuff thats been added since the last list which was a month ago, lol :p
Just off the top of my head...
Replace all suspension bushings with OEM ones :roll:
Fit some kind of soundproofing (Recommendations welcome) :scratch:
Complete re-trim in black leather 8)
Fix an oil leak somewhere around the gearbox :indiff:
Fix the sunroof :mad:
I'll probably add to the list as the C is now locked away for the winter.
First job got to be Lupo wipers so that I'll be able to see now that its pouring down.
Needs lowering to a respectable hight
Wheels re-furbed
Induction kit
Rust removed from rear panel
Bonnet and few stone chips resprayed
Finally win lottery or rob bank to pay for it all :mrgreen:
