sambo 0 Posted November 10, 2004 Just tryed changing my stub axle, all unbolted and came off apart from stuborn abs sensor which is stuck within rusty stub axle! Any advice how to remove it? I'v cleaned it as much as poss and soaked it in wd40. Can i try gently knocking it out? Thanks Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 10, 2004 Heat it up!! Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted November 10, 2004 I ended up using a hammer and chisel... Quote Share this post Link to post Share on other sites
sambo 0 Posted November 11, 2004 Done now, lots of penetrating oil and a whack with a soft hammer! Quote Share this post Link to post Share on other sites
stevemac 0 Posted November 11, 2004 I had to burn mine out with a blowtorch. The stub axle had corroded inside the mounting hole & the sensor was stuck solid. Quote Share this post Link to post Share on other sites
